Using HD Template in HD PAL?
COW Forums : Apple Motion
Sjaak Doedens
on Aug 27, 2010 at 8:40:09 pm
Hi there,
I want to use the HD template Float (Motion) in a HD project with 25 fps (I live in PAL country). The properties of this template is a framerate of 29,XX. Can I use this in a project with 25 fps (FCP) after editing? If 'YES', I've no problems (lucky me), if it is a 'NO', what can I do to make this possible?
Sjaak
Stephen Smith
Re: Using HD Template in HD PAL?
on Aug 27, 2010 at 9:04:51 pm
Create a new project with your Pal settings. Drag the group/groups from the HD template into the Pals time line or project pane and Motion will convert the template to the new frame rate. You will need to adjust the size of the group/groups so it is best to get everything in the HD template into one group. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
