Photoshop Layers Out of Alignment
COW Forums : Apple Motion
Brent Streeper
on Aug 27, 2010 at 7:56:31 pm
I've got a Photoshop file that I need to animate in Motion. The psd file is RGB 8bit and has 2 layers.
When I bring the psd file into Motion, the top layer is scaled way up and has different x,y position coordinates than the bottom layer. I can almost get the top layer to line up with the bottom, but it's still slightly off.
Any thoughts on how to import the psd into Motion so that the layers line up correctly?
Brent
Motion 4.0.1
Photoshop CS
Mark Spencer
Re: Photoshop Layers Out of Alignment
on Aug 27, 2010 at 8:51:05 pm
Make sure your Motion project file has the same pixel dimensions as the Photoshop file.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Brent Streeper
on Aug 27, 2010 at 9:54:20 pm
Thanks for the response!
The psd file is larger than the 4096 pixel limit. It's a scan of a dollar bill that I want to get super close in on, and then pull back to reveal the full bill. Is there a way around the size limit?
zak peric
on Aug 27, 2010 at 9:01:36 pm
you can check this in Apple Motion by going to edit project properties. I hope this helps...
