Object on end of a string - Cool Idea; How to Execute?
COW Forums : Apple Motion
Landon Satterfield
on Aug 17, 2010 at 5:53:13 pm
Hey guys,
I have a question that's not so much a pressured troubleshoot.
i have a great idea but no where to start. Motion behaviors behave so violently inconsistent
that I've lost a lot of trust in them.
The idea is simple:
I want to have an object (say, a rectangle) drop from the "ceiling" on a string that draws taught
whenever the object reaches the end of the string. I want it to pop with some realism, causing
the object to shake and spin.
I'm thinking of when someone drops a necklace while still wrapped around one finger.
That *snag* and sway that happens is what I am looking for.
I appreciate you guys so much for your help. You are all awesome.
Thank you for any advice you can give on behaviors and all things Motion.
-LS
Mark Spencer
Re: Object on end of a string - Cool Idea; How to Execute?
on Aug 17, 2010 at 6:08:21 pm
You might try the Spring simulation behavior to get started.
Can you give an example of a behavior acting "violently inconsistent"? I've never seen that.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Stephen Smith
on Aug 17, 2010 at 6:14:22 pm
Check out my Particle Party tutorial. I think it can get you a step in the right direction. Best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Landon Satterfield
on Aug 17, 2010 at 7:15:40 pm
Yeah, I can check out Spring, that's a good idea.
Has anyone ever made a physical string, that moved like one, in Motion?
"violently inconsistent" or just not working at all despite parameters being adjusted.
Quantize has never worked for me. I always result to a Strobe filter. In this instance
it was pretty effective. I liked the result - the black shapes.
I'll check out Particle Party for getting instructions on how to do this then tell you
what I think. I haven't had a chance to look at it yet.
Thank you guys for your help!
Gareth Randall
on Aug 18, 2010 at 6:39:23 am
[Landon Satterfield] "Has anyone ever made a physical string, that moved like one, in Motion?"
It's fairly straightforward to make a swinging pendulum out of a solid line, but do you want a string that will go slack or taut in a realistic way? If so, not sure how you'd do that in Motion without tediously having to hand-animate points on a Bezier shape.
