Primatte Keyer Pro, Motion, and Final Cut Pro
COW Forums : Apple Motion
Tom Morton
on Aug 12, 2010 at 3:29:28 pm
Hello all,
I'm new to using Primatte Keyer Pro 4.0, but from what I've used so far its great!
I have my edited piece in Final Cut Pro. I export the sequence to Motion, apply the Primatte Keyer Pro filter, and then save the project. When I jump back into Final Cut Pro, this strange transparency issue happens. There is no to describe it, so here is a "before and after" screen shot I've created: http://imgur.com/y4Yct.jpg
The top screen is my project sitting in Motion, while the bottom is when I look at it in Final Cut. There are no other filters, and I've tried doing a Vanilla drop of the filter (changing no other settings besides the Auto setting to get the green out of there) and I cannot get anything to work.
While I love After Effects, Motion works into my workflow so much easier.
Any and all advice is greatly appreciated. From one frustrated forum member to another, thanks!
Andy Neil
Re: Primatte Keyer Pro, Motion, and Final Cut Pro
on Aug 13, 2010 at 1:05:03 am
Strange. Seems like the problem might be with Primatte? Have you called/emailed their tech support?
Andy
http://www.timesavertutorials.com
Tom Morton
on Aug 13, 2010 at 1:05:46 am
I have, no response from their official forums either.
Mark Spencer
on Aug 13, 2010 at 1:18:37 pm
What if you render the shot out of Motion directly and drop that into FCP?
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Tom Morton
on Aug 13, 2010 at 1:23:02 pm
I can do that, it works fine, but the whole reason I stopped using After Effects to do all my Keying was so I could easily switch between the keying program and Final Cut, rather than have to re-render every time a change has to be made.
Mark Spencer
on Aug 13, 2010 at 4:51:54 pm
Agreed, just wanted to make sure you had a workaround. Sounds like some sort of graphics card issue...not sure what you can do about it though, sorry.
Mark Spencer
Jason Diebler
on Aug 13, 2010 at 6:15:57 pm
Tom, I suggest using the Primatte Keyer Pro filter inside of Final Cut Pro. When you install this plug-in, you have the choice to designate which program you'd like to run it in... Motion or FCP.
Give it a shot in FCP, I think you'll be happier. I have it installed in both apps, but I opt to do all of my keying in FCP. For whatever reason, the adjustments are easier inside of FCP as well.
If you've already put a lot of time into this, export ProRes 4444 from Motion for now, but try it next time in FCP just for grins.
"The deepest blues are black" - Foo Fighters
(this doesn't help me when I'm chroma keying!)
Tom Morton
on Aug 13, 2010 at 9:14:46 pm
I installed the plugin for both, but something in my brain said that Motion would be the better choice. I played with the plugin in FCP and it seemed a little harder, but upon your reply I am going to revisit it for next weeks episode.
Appreciate the feedback from everyone, thank goodness the plugin works in FCP!
Ricky Dominguez
on Oct 3, 2010 at 7:50:47 pm
This has happen to me if I rendering in 10bit YUV, cheek sequence settings/video processing and change to 8bit and all is OK, I don't know why it do this but it's a fix for me.
Another problem that I have is that this plugin make FCP or Motion crash many times.
