Motion and graphic path
COW Forums : Apple Motion
Eric Holzapfel
on Aug 10, 2010 at 5:54:07 pm
Hello Motion Group,
I am planning to use a map image (tiff or psd, etc). I would like to trace a path from one
city to another, etc. Like Raiders of the Lost Ark, or like they did in the 30s and 40s when
the film showed the "route" of intrepid travelers. I can do something like this in Flash, by creating a path over the map, from city to city, and have Flash draw a line, and move a round dot along the path. I do not want to follow a straight path, but have the path follow "roads" on the map.
I want to use this concept for a travel film I am working on, which will use FCP timeline with stills and
video. Can I do this in Motion? Is Motion a realistic choice for this type of work? Or AfterEffects?
Eric
Stephen Smith
Re: Motion and graphic path
on Aug 10, 2010 at 6:09:32 pm
I think Motion is a great choice for a project like this. Its Write on Behavior makes this easy to do. I would Use the B-Spline tool to create a line and then add a Write on Behavior to animate the line. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Eric Holzapfel
on Aug 10, 2010 at 6:47:47 pm
Hello Stephen,
Thanks, I have motion 4, and this will be a good learning exercise for me.
eric
Final Cut Pro, Adobe After Effects, Photoshop
Andy Neil
on Aug 10, 2010 at 6:53:46 pm
The write on behavior works for drawing the line. For the animation of a dot along the path, you should use the Motion Path behavior. Check out my quick tutorial that shows exactly that.
Andy
http://www.timesavertutorials.com
Eric Holzapfel
on Aug 13, 2010 at 2:02:33 am
Hello Andy,
Great help. How did you know that my map i intend to use for animation is very
much like yours!!
eric
Andy Neil
on Aug 13, 2010 at 5:22:20 am
I just assume that everyone needs a map between Exeter and Norwich.
Andy
Gareth Randall
on Aug 13, 2010 at 12:13:23 pm
Hi Andy,
Great tutorial, but just FYI, Norwich is pronounced "Norritch" ;)
Andy Neil
on Aug 13, 2010 at 4:14:50 pm
I don't get it. How can you brits pronounce the "H" in herbs, and not the "W" in Norwich?
Andy
Gareth Randall
on Aug 14, 2010 at 12:51:16 pm
We pronounce the "h" in "herb" because that's the correct way ;)
Actually I think the real reason is that the Pilgrims left England at a time when "herb" was pronounced "erb". Over time the pronunciation changed in the UK, but obviously not in America.
Similar reason as to why you guys don't celebrate Boxing Day after Christmas Day - the Boxing Day holiday wasn't invented until some time after the Pilgrims left.
As for Norwich... there's a Norwich in Vermont, and according to Bill Bryson, older Vermonters still pronounce it the British way, despite a general push towards "Nor-witch" :)
Mark Petereit
on Aug 10, 2010 at 6:53:48 pm
Here's a tutorial that covers exactly what you want to do:
http://www.motionsmarts.com/tutorials/drawinglines/drawinglines1.html
Mark Spencer
on Aug 10, 2010 at 7:11:40 pm
That tutorial was great for Motion 2 but if you have Motion 3 or 4 using a paint stroke and a write on behavior is much easier.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Mark Petereit
on Aug 10, 2010 at 7:32:08 pm
LOL! Sometimes Google is NOT your friend. ;-)
Thanks, Mark!
Eric Holzapfel
on Aug 13, 2010 at 2:06:28 am
Hello Mark,
What a great resource the Cow is. Also, thanks for the input. i have your
Motion 3 and Motion 4 traing DVD (via iTunes) and it is great.
Eric
