Motion exporting black screen
COW Forums : Apple Motion
Matt Simpson
on Aug 9, 2010 at 8:29:05 pm
I have some scrolling text I have created in Motion. When I export it as white text on a black background it works fine. When I reverse it to black text on a white background all I get when it is exported is a black screen. The first few times I did this it worked fine and then it stopped exporting correctly and was just black. Any ideas on what could have caused this?
Stephen Smith
Re: Motion exporting black screen
on Aug 9, 2010 at 9:54:06 pm
I think it is easiest to take the Motion project file directly into FCP instead of exporting a clip. Are you saying you want the white background and it is not showing up?
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
zak peric
on Aug 9, 2010 at 11:33:07 pm
Please make sure that you have a white square created with the rectangular tool (colour it with white). Also if you want to have a white Background by default go to edit Project Properties and change the option from Transparent to Solid and then change the colour from black to any colour you want. Then render the animation. See my image for more details:
I hope this helps:
Matt Simpson
on Aug 16, 2010 at 5:37:48 pm
Changing the background to solid worked. I don't know how it got changed to transparent but now I know what to look for.
Thanks for your help!!
