Using Motion 3 and Photoshop at the same time
COW Forums : Apple Motion
Alex Udell
on Aug 3, 2010 at 3:57:28 pm
Hi all,
We do a lot of work in Photoshop with motion.
In some cases once I've brought a file into motion, I can make changes with Photoshop while Motion is open. In other cases, Photoshop will tell me the file is in use when I try to save it, requiring me to close motion and then re-poen after saving.
Oddly just closing the motion Project file doesn't do it either. I have to close motion entirely.
I can't seem to identify what I'm doing different in each case.
It would be very convenient to just be able to always edit my PSD's with motion open.
So If anyone can help, that would be terrific!
Alex
Stephen Smith
Re: Using Motion 3 and Photoshop at the same time
on Aug 3, 2010 at 4:03:04 pm
Once the file is saved in Motion you most close Motion to make changes to the Photoshop file. If you don't save the project then it will not ask you to close Motion. Hope this helps answer your question. Best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Alex Udell
on Aug 3, 2010 at 4:08:46 pm
do autosaves count? (i'd doubt it as they have separate file names)
Alex
Stephen Smith
on Aug 3, 2010 at 4:10:34 pm
I'm not sure, I'd have to run a test. Let us know what you find out.
Stephen Smith
