Export is transparent
COW Forums : Apple Motion
Bryce Moose
on Jul 17, 2010 at 4:20:20 pm
Hello, I am trying to make a basic logo for a video and when I export it with no transparency and send it to final cut pro 7 it is transparent. It's not supposed to be transparent. It also gives me black behind it. I have to choose composite mode screen in order to remove the black in final cut pro and this is when it becomes transparent. Is there a way to fix this?
thanks.
Dan Johnson
Re: Export is transparent
on Jul 17, 2010 at 6:15:07 pm
In order to make the export transparent export out as Quicktime Animation set to Millions Color +. Or Pro Res 444. They are the only video codecs that support transpancy.
You can also just bring the project file direclty into Motion and it will remain transpent.
Bryce Moose
on Jul 17, 2010 at 6:20:37 pm
Did you even read what I wrote? I DON'T want it to be Transparent.
Bryce
Mark Spencer
on Jul 17, 2010 at 7:43:53 pm
Edit > Project Properties - change the Background from Transparent to Solid.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
