Motion 4 - eliminate background of Content
COW Forums : Apple Motion
Paul Boone
on Jul 11, 2010 at 8:37:24 pm
I'm making a display for a summer camp game called, "Dragon King", and I want to use "Fire Burst 2" under the Library-Content section of Motion. I just want the fireball going over my background though, and cut the black background that is underneath the fireball. Is this possible seeing as how they are one connected image? Can I turn all the black to clear or something?
Paul
Mark Petereit
Re: Motion 4 - eliminate background of Content
on Jul 11, 2010 at 9:48:41 pm
Look up Basic Compositing in your manual. The section you want is "Editing Opacity and Blending Parameters".
Gareth Randall
on Jul 11, 2010 at 9:57:17 pm
Hi Paul,
One way to make the background transparent is to apply the Color Key filter (in Filters>Keying) to the fire clip, then use the eyedropper to sample the black. This will tell Motion to "key out" (remove) the black parts of the clip and let the layers underneath show through. Once you've done this you will probably want to tweak the result, either by adjusting the Tolerance slider, and/or adding the Matte Magic filter as well.
Alternatively, depending on the precise effect you want to achieve, you could apply the Luma Key effect instead of the Color Key, and set it to Key Out Darker.
Even more alternatively, you could forgo any filters altogether and try simply setting the Blend mode of the fire clip to something like Add, Lighten, Screen or Color Dodge. Any of those will drop the black background out and composite the fire clip onto your background, although each will give a the resultant composite a different "feel".
