Looping a Motion made Animation
COW Forums : Apple Motion
Andree Franks
on Jun 23, 2010 at 8:01:10 am
I created a shape (circle) with a line that rotates clockwise 360 degree using a Ramp behavior on its Rotation axel for a second.
So he shapes and animation is one second long, now I want to this animation to repeat itself for 10 seconds (for example).
Now in Video clips you can Loop the end state, but not in a made Animation. How would I go by this?
Mark Spencer
Re: Looping a Motion made Animation
on Jun 23, 2010 at 1:22:53 pm
Use keyframes instead of the Ramp behavior, and in the Keyframe Editor, use the Animation Menu to set After Last Keyframe to Repeat.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Andree Franks
on Jun 23, 2010 at 1:34:19 pm
Oh, wonder why Apple couldn't put that option in the Timing! But now I know!
THANKS!
Anders Larsen
on Jun 24, 2010 at 8:37:39 am
You could also just make the behavior 10 seconds long, and set the rotation to 3600 degrees.
Andree Franks
on Jun 24, 2010 at 2:25:51 pm
True but that is not the elegant Apple way ;)
mark pigott
on Oct 6, 2011 at 5:48:22 pm
I am having trouble finding this in Motion 3, does it exist in this version?
FOUND IT! NEVER MIND!!!!
Mark Spencer
on Oct 6, 2011 at 6:26:47 pm
Properties Inspector, Timing section at the bottom, set the End Condition to Loop (for a video clip). Fro keyframes, use the Keyframe Editor to set After Last Keyframe to do what you want.
Mark Spencer
mark pigott
on Oct 6, 2011 at 8:27:41 pm
Yes thanks I found it.
