50 fps project
COW Forums : Apple Motion
Andrei Bocharnikov
50 fps project
on Jun 8, 2010 at 1:22:16 pm
Why I am not able to create 50 fps project?
I was trying to use one of the 50fps presets but it just jumps to custom. When in custom I do not have 50 fps option at all.
I did try to import 50 fps footage and project still does not give 50 fps option in the settings or I did try to create new project and set it up... no way!
Please if anyone has some clue to what is going on?
Motion v. 4.0.2
MacPro Dual Quad 2.8 GHz, 4 GB DDR2 SDRAM, Leopard 10.5.8, QT 7.6.6, FCS3
Mark Spencer
Re: 50 fps project
on Jun 8, 2010 at 1:27:26 pm
Just create a new custom project (don't start with a preset) and select the frame rate you want.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Andrei Bocharnikov
Re: 50 fps project
on Jun 8, 2010 at 1:38:32 pm
Thank you, Mark, for reply!
It did not help (as I wrote in my OP). There is no option for 50 fps at all, no po-up/pull-down menu for frame rate option.
check the video below:
http://reels.creativecow.net/film/50fps
Mark Spencer
Re: 50 fps project
on Jun 8, 2010 at 1:46:58 pm
That's because you are editing the project properties of an existing project. You create a NEW custom project, you can choose any frame rate you want.
Mark Spencer
Andrei Bocharnikov
Re: 50 fps project
on Jun 8, 2010 at 2:09:38 pm
Mark please check new video. I am creating new project (same as before) and there is nothing to change.
http://reels.creativecow.net/film/4864
Mark Spencer
Re: 50 fps project
on Jun 8, 2010 at 2:13:49 pm
You have bypassed the new project dialog - you must have selected the checkmark to turn it off - turn it back on in preferences so that when you create a new project, you are prompted for a preset - choose Custom at the bottom of the list and choose your frame rate etc.
Mark Spencer
Andrei Bocharnikov
Re: 50 fps project
on Jun 8, 2010 at 2:22:09 pm
Mark,
Yes, it was the problem. In my preferences in presets section I had checked option to use default preset for new projects. I unchecked it and now I have beautiful new project setup dialog box.
Thank you!
Andrei
Mark Suszko
Re: 50 fps project
on Jun 8, 2010 at 4:22:54 pm
What screen recorder did you use to make your demo movie?
Andrei Bocharnikov
Re: 50 fps project
on Jun 8, 2010 at 8:02:56 pm
It is Snapz Pro X
