Line randomly appearing
COW Forums : Apple Motion
anthony Faulkner
on Jun 4, 2010 at 2:10:23 am
Hi I am working on this 3-D project.
It is pretty much complete, but I have this annoying line that keeps appearing once the project is rendered or exported out. In any codec. It doesnt appear in motion just when it gets to FCP or quicktime.
it appears in the intersection of two wall pieces. the thing is the floor is situated on top of the two wall pieces. and as the camera rotates from left to right it flickers on and off.
It looks like this
here is a top view of my layout of objects if that helps diagnose this issue.
any help would be appreciated!
Anthony
zak peric
Re: Line randomly appearing
on Jun 4, 2010 at 8:10:04 am
looks like your intersections of the walls are OK. They should be going one through another, cutting in. Can you tell me please have you set your rendering option to best or is it set to normal. Go under RENDER Menu and set it to Best then export your animation with Animation codec millions of colours. Give this a go if you have not already tried it.
See my image for more info.
