Spinning masks?
COW Forums : Apple Motion
Stephen Odom
Spinning masks?
on May 10, 2010 at 4:33:02 am
Hello all,
I have a large drop zone that is masked by several spinning cells. Unfortunately, when the masks spin, the picture that is being masked does not hold the frame of the photo that I was hoping.
Is there a way to rotate a frozen cell without having to cut up a picture? If this does not make sense, I can post still frames.
Thank you for your assistance!
Stephen
Andy Neil
Re: Spinning masks?
on May 10, 2010 at 5:37:29 pm
If you're looking to spin parts of an image independently of each other, then you either need to cut up the original pic, or create several clones, each with it's own mask, and rotate the clones.
Andy
Stephen Odom
Re: Spinning masks?
on May 10, 2010 at 8:23:02 pm
Spinning the cropped clone layer is a bit more work than expected, but the process works. Thank you Andy!
