write on
COW Forums : Apple Motion
Jodi Binstock
write on
on Apr 28, 2010 at 1:36:02 am
I'm trying to write on the yellow outline here. Can anyone guide me through the steps?
Thanks.
Jodi
Mark Spencer
Re: write on
on Apr 28, 2010 at 1:56:15 am
Do you have the artwork as separate layers? If not, you'll want to break out the parts you want to write on, then cover them with paint strokes, animate the paint strokes with the write-on behavior, and use those paint strokes as an image mask applied to your yellow lines.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Jodi Binstock
Re: write on
on Apr 28, 2010 at 4:51:08 am
So great. Thank you. How do I use the paint strokes as an image mask. I managed to draw the tree (It drew white) I managed to write on the paint strokes, but what I can't yet figure out is how to make the draw on the yellow image behind it.
Thanks.
Jodi
Mark Spencer
Re: write on
on Apr 28, 2010 at 1:07:16 pm
Select the yellow image. Chose Object > Add Image Mask. Drag your paint stroke to the well in the HUD.
Mark Spencer
Stephen Smith
Re: write on
on Apr 28, 2010 at 2:13:21 pm
Here is a video tutorial with an example of how to use an image mask. It is in the middle of the Creating a Hologram tutorial. Best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
