Illustrator graphics " jumping" during dissolve
COW Forums : Apple Motion
Anna Whyte
on Apr 1, 2010 at 4:57:52 pm
I am using a lot of illustrator graphics and they work unless I make some simple moves with motion. Then there is a small jump during the dissolve. I'm using FCP7 and Illustrator CS3 or 4, motion 3.5
Phil Williams
Re: Illustrator graphics " jumping" during dissolve
on Apr 2, 2010 at 9:48:57 am
This seems to be a longstanding bug, I've had it happen in both Motion 3 and 4, but with me it tends to happen more with text I've typed within Motion - every so often, a single letter in a line of text will hop slightly in the Y axis, just for one frame.
Sometimes re-rendering it will fix it, sometimes it won't. In the latter cases, changing the font, rendering, then changing the font back to the one you really want seems to be a workaround.
