Motion to FCP quality loss
COW Forums : Apple Motion
Mike Petriano
on Mar 16, 2010 at 10:12:29 pm
Just got Motion 4. I've never used it before. Besides little problems I'm having with my lack of knowledge, I created scrolling text, exported to FCP using an Animation QT compression.
My FCP project is NTSC SD (is going to be a featured DVD sold on our website)
The motion, looks good when played with QT but in FCP is flickery and blurry.
What settings should I set the motion export, so that I get a clean smooth look to the scroll when imported onto a FCP SD NTSC timeline.
Best,
Mike
Mark Spencer
Re: Motion to FCP quality loss
on Mar 16, 2010 at 10:15:03 pm
Read this:
http://www.kenstone.net/fcp_homepage/motion_text_in_fcp_spencer.html
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Stephen Smith
on Mar 16, 2010 at 10:16:10 pm
Be sure to set it to best when you export. You can also place the Motion project file into your Final Cut Pro timeline and render it there so you don't have to export. In FCP go to Sequence, settings, Render Control and set Quality to Best. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Mike Petriano
on Mar 16, 2010 at 10:20:58 pm
Thanks a lot!
Hey, by any chance. What settings would you use to export to NTSC SD for solid results, if you had no size restrictions? (besides uncompressed, some reason that doesn't work in FCP)
Best,
Camren
Stephen Smith
on Mar 16, 2010 at 10:25:46 pm
I've really liked the Animation codec. It was the default for Motion 3. The Pro Res works well also. Just my two cents.
Stephen Smith
Mike Petriano
on Mar 16, 2010 at 10:28:34 pm
Thanks again
Stephen Smith
on Mar 16, 2010 at 10:35:28 pm
Happy to help, best of luck.
Stephen Smith
