Final Cut Pro Send to Motion causes interlace problems?
COW Forums : Apple Motion
Deborah White
on Mar 7, 2010 at 7:48:28 pm
I wanted to use the image stabiliser in Motion. In my FCP timeline I sent the clip to Motion but in Motion the clip has interlace issues that where not apparent in FCP. What is causing this and any thoughts on how to solve it?
Is Motion using a different codec from FCP?
Deborah
Mark Spencer
Re: Final Cut Pro Send to Motion causes interlace problems?
on Mar 7, 2010 at 8:45:48 pm
The interlace problems weren't apparent in FCP because FCP's Canvas by default only shows you one field, while Motion shows you both fields.
But there is no reason to go to Motion to stabilize a shot, since FCP has the Smoothcam filter, which does exactly the same thing.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Arnie Schlissel
on Mar 8, 2010 at 5:18:47 am
You will have the same exact interlacing problems if you try to stabilize the footage in FCP.
Stabilizers work by shifting the image around to compensate for the motion of the camera. If it senses the camera moving up, the clip is shifted down, camera left, clip right, etc. All stabilizers work this way.
If you shift the clip up or down, you will reverse fields. That's why the FCP manual warns against stabilizing interlaced material.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
