Trigger values by a formula?
COW Forums : Apple Motion
Oliver Szalab
on Mar 4, 2010 at 3:58:38 pm
I'm working a lot with drop zones representing footage I don't know anything about (e.g. dimensions), which is kind of crucial when it comes to "Replicate" or similar effects. So here's my question:
is there a way to trigger certain inputs (like the rows/columns in the Replicator) by a formula based on the (yet unknown) dimensions of the footage which will be mounted in the replicated drop zone?
Cheers
Oliver
Mark Spencer
Re: Trigger values by a formula?
on Mar 4, 2010 at 5:28:32 pm
Nope. You can use the Link parameter behavior to control the parameter of one layer with the parameter of another (e.g. the number of rows or columns could be controlled by the scale of another layer) but the dimensions of a layer is not a parameter.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Oliver Szalab
on Mar 5, 2010 at 8:01:52 am
ah, ok. thank you very much.
let's see, what i can do with linking
