"content" folder disappeared
COW Forums : Apple Motion
Alex Ordiner
on Mar 2, 2010 at 3:30:39 pm
hi to all!
i've a little problem with motion 4.
In the library tab, the Content folder is empty. All the other folder is OK, only that is missing...
The real folder /Library/Application support/Final cut/Motion/Library/Content is OK
i've change the path in preferences tab, copy to another position,...
but nothing append.
any suggestion?
I can't drag a "content present" from finder to motion (the extension is .molo
-----edit----
I already tried trashing the preferences ~/Library/Preferences/com.apple.motion.plist
Stephen Smith
Re: "content" folder disappeared
on Mar 2, 2010 at 3:54:48 pm
Make sure you don't have any content in the search feature.
Try going to the Preferences and reset the "Content Library & Templates" Library Path in the General section. Best of luck.
Other wise take a look at this article: http://support.apple.com/kb/HT1885
Best of luck and hope this helps.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Alex Ordiner
on Mar 2, 2010 at 4:31:55 pm
thanks stephen.
unfortunately I already tried these solutions...
the only one is reinstall, but not now.
Very thanks
