Apple render will not stay transparent in FCP
COW Forums : Apple Motion
Vincent Strader
on Feb 26, 2010 at 10:42:53 pm
I select Transparent in my motion project, and the window goes transparent with my particle effect previewing.
I export to a QT, then import the file into FCP.
Inside FCP it has the full black background and covers up the whole screen with the particle effect playing.
What am I doing wrong?
Thanks for any suggestions,
Vinnie
cowcowcowcowcow
Stephen Smith
Re: Apple render will not stay transparent in FCP
on Feb 26, 2010 at 10:47:00 pm
You can drag the Motion Project File into FCP and it will keep it transparent. I you want to Export it out Set It to QuickTime's Animation codec. Make sure it is set to Millions Color +. The plus stands for the transparency you want. Best of luck and hope this helps.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Anthony Popolo
on Feb 28, 2010 at 2:30:03 am
Don't export it from Motion. Just save the project file in Motion. Then import the motion file (.motn) in Final Cut and render it there.
Vincent Strader
on Feb 28, 2010 at 2:51:01 am
That's awesome. Thanks to both of you two. I'm not in the office at the moment, but I'll give it a try when I get back in.
Thanks again!
Vinnie
Stephen Smith
on Mar 1, 2010 at 3:28:36 pm
I'm happy to help. Best of luck.
Stephen Smith
