Shortcut for 1:1 replacement of elements?
COW Forums : Apple Motion
Mark Suszko
on Feb 26, 2010 at 5:50:06 pm
Say I built a complicated sequence in Motion 3 that has a "floor" and "distant sky" backdrop, (pictures made in photoshop as tif or png) against which I did all kinds of flying camera moves, and now the client wants to change just the "floor" element.
What is an easy way to replace that one element without changing anything I have key-framed or positioned?
Thanks for the help.
Stephen Smith
Re: Shortcut for 1:1 replacement of elements?
on Feb 26, 2010 at 6:07:48 pm
You can drag a new floor from your File Browser and drag it onto the other floor. You will get a hooked shaped arrow. Let go of the mouse and it will swap the floors.
Or you can select the floor and go to the Properties tab. Down at the bottom you will see a Media section. Hit on the To button and you can choose to swap it with another clip in your projects.
Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Mark Suszko
on Feb 26, 2010 at 6:20:05 pm
It does, and you rock out loud, Steven.
Stephen Smith
on Feb 26, 2010 at 6:35:26 pm
I'm happy to help and thanks for the kind words.
Stephen Smith
