how do you flop lower third template to opposite side of frame?
COW Forums : Apple Motion
Anthony Smedile
on Feb 22, 2010 at 1:02:46 am
Does anyone know how to flop a motion lower third template from screen left to screen right? when choosing the lower third from the template options, it only gives you one choice but I assume there is an easy way to flop it since not all interviewees sit on one side.
Stephen Smith
Re: how do you flop lower third template to opposite side of frame?
on Feb 22, 2010 at 3:48:58 pm
Anthony,
You make a really good point. They should come with a Lower Third on the right and left.
The only way I know how to do it is the old fashioned way. Luckily with Lower Thirds like the Weave-Lower-Third the text and lower third are in separate groups. In this case, select the "Arrows" group and change it's Y rotation 180 degrees. That will put it on the other side. Then move the text. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
zak peric
on Feb 23, 2010 at 8:35:35 pm
You can also use Flop Filter to change rotation of the object. Filters/distortion/flop.... (Not the text, you will have to move the text manually).
Anthony Smedile
on Feb 26, 2010 at 3:33:14 pm
Thanks for all the help! The flop filter worked great but since the text was animated, it was too difficult to figure out how to change all the parameters to the other side of the frame. Oh well, that's what I get for trying to take a short cut. damn those templates!
Stephen Smith
on Feb 26, 2010 at 4:55:59 pm
Which template was it?
Stephen Smith
Anthony Smedile
on Feb 27, 2010 at 12:41:55 am
It was the Skyline template. Weird that they wouldn't include both sides of the screen. ah whaddya gonna do?!
Stephen Smith
on Mar 1, 2010 at 7:27:00 pm
Here is a link to the template with the lower third on the right:
575_skylinerightlowerthird.motn.zip
Stephen Smith
