Frutiger "A" cut off?!?
COW Forums : Apple Motion
Brandon Adams
on Feb 13, 2010 at 12:54:30 am
I'm really not sure what is causing this problem. The letter "A" in my Frutiger font is getting cut off in FCP and AE and Motion. It shows up fine in Linotype FontExplorer and Word. It is in PostScript format if that makes a difference.
Here is an example http://dl.dropbox.com/u/2056709/Picture%204.png
Anyone have any ideas?
-Brandon
-Brandon
Mark Spencer
Re: Frutiger "A" cut off?!?
on Feb 13, 2010 at 1:25:49 am
In Fontbook, validate the font.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Brandon Adams
on Feb 13, 2010 at 1:28:30 am
I couldn't install it with Font Book and it won't show up in it. I had to install it using Linotype FontExplorer.
-Brandon
Noah Kadner
on Feb 13, 2010 at 2:39:55 am
Then I'd sub in another font- if you can get it to install with Fontbook probably not going to be happy in Motion.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Visit my Editors Blog- Tips and Gear for Editors.
Brandon Adams
on Feb 13, 2010 at 2:45:36 am
I have to use Frutiger. Client brand. It's purchased from Adobe so there's nothing wrong with the font itself.
-Brandon
Noah Kadner
on Feb 13, 2010 at 11:37:42 pm
Well then I'd check in with them- perhaps you have the wrong version for Mac OS X.
Noah
Mark Spencer
on Feb 16, 2010 at 2:20:56 pm
Is it a TrueType font? Open Type? You may need to convert it.
Mark Spencer
Mark Chatwood
on Jan 10, 2016 at 4:26:14 pm
I know this is an old thread, but I just had the same problem with ITC Avante Garde Bold, and have just now solved it in Motion 4, so thought I'd better share it just in case others are pulling their hair out like I was!
I downloaded the font in Open Type format (.otf), unzipped the file, then installed it using Fontbook. I then converted it online to a True Type format (.ttf). Here's where the problem is - you've got two versions of the same font on the computer, and when I typed the word 'COMMUNICATION' in Motion, the ends of the 'C's were cut off!
To solve it, open Fontbook, find the font, right click and select 'Validate Font', as Mark suggests above. Check the box next to the .otf version, and click 'Remove Checked' at the bottom of that window. Then open up Motion again, and your font should work. At least mine did!
