Change Single Z-location on shape
COW Forums : Apple Motion
Ralph Johnson
on Feb 12, 2010 at 6:11:36 pm
Is it possible in MOTION to move the z-location of just one point on a square created with the rectangle tool (i.e., without moving the remaining points on the square. Thanks.
Mark Spencer
Re: Change Single Z-location on shape
on Feb 12, 2010 at 6:13:15 pm
Shape control points only include x and y as you can see in the Inspector - they are always flat planes (that you can rotate in 3D space)
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Ralph Johnson
on Feb 12, 2010 at 6:18:23 pm
What if I create the square using the B-Spline or Bezier tool. It is then possible to move a single point on the construct in the z-dimension without disturbing the others points on the construct? Thanks for the earlier response. I could see in the inspector that only two dimensions could be altered, but hope there was a work-around. I appreciate your advice.
Mark Spencer
on Feb 12, 2010 at 6:20:00 pm
The workaround is to not use a shape, which is always a 2D plane. You can use a replicator or an emitter on a motion path - the control points of a motion path have x, y, and z.
Mark Spencer
Ralph Johnson
on Feb 12, 2010 at 6:21:04 pm
Got it. Thanks!
Ralph Johnson
on Feb 12, 2010 at 6:35:54 pm
It seemed so simple reading your words on the post, but I can't make it happen. Could you just give me a quick outline as to how to create a square using a motion path? Thank you so very much.
Mark Spencer
on Feb 12, 2010 at 6:37:29 pm
You have to draw it by hand by double-clicking on the path to add control points and moving them....
Mark Spencer
Ralph Johnson
on Feb 12, 2010 at 7:54:51 pm
How do I get something (anything) on the motion path? Sorry. Thanks for your patience and very helpful information.
Mark Spencer
on Feb 12, 2010 at 8:11:26 pm
One way is to replicate a small circle and use the motion path as the shape source for the replicator.
Mark Spencer
