Missing Z-axis rotation
COW Forums : Apple Motion
PJ Palomaki
on Feb 4, 2010 at 12:55:34 pm
Any idea why a shape exported from Illustrator as a Motion Shape (via Export as Motion shape script) lacks Z-axis rotation when brought to Motion? X and Y axis can be rotated but there isn't Z axis available. Is this a bug in the export script or am I just missing something?
The object has no filters or behaviours applied.
See picture...
Mark Spencer
Re: Missing Z-axis rotation
on Feb 4, 2010 at 2:12:05 pm
That's very odd - can you rotate it on the z-axis in the Inspector - IOW, is there a handle sticking out of the anchor point?
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Scott Hyldahl
on May 27, 2011 at 7:19:38 pm
I'm having the exact same problem and have always been when using the Illustrator script. There is a handle coming out of the anchor point of the shape, but if I want to use parameters on the z-rotation, I'm out of luck because z-rotation doesn't show up in the inspector. The only way I can seem to animate the z-rotation is by using the record button and manually rotating it with the handle. Anybody have any further insights into this?
Lukas Gähwiler
on Nov 16, 2012 at 1:52:06 pm
same problem also here: no z-axis on illustrator-scripted shapes.
I create a clone of the shape and then you have a z-axis on the clone…
