Creating an "oil painting" effect in Motion
COW Forums : Apple Motion
Chris Tomkins
on Jan 21, 2010 at 5:38:21 am
Hi
I'm trying to make a piece of footage look like an "moving" oil painting - just wondering if people had any ideas for how I could achieve this before I give up and have to buy an expensive plugin.
I've tried mixing silks and crystallizing and wide time which is not too bad, but I'm sure there's a better way...
Cheers
Chris
Arnie Schlissel
Re: Creating an "oil painting" effect in Motion
on Jan 21, 2010 at 2:10:35 pm
You may want to try adding an edge detection filter and cranking that way up. Look for "Edges" and "Edge Work".
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Mark Suszko
on Jan 21, 2010 at 2:40:45 pm
I used to use a freeware version of Synthetik StudioArtist for this, but also there are a number of free resources in the Photoshop community where they have created automated batch processes you can apply to the images in a folder. You can download the droplets or specs for free, or make your own, by just turning on the actions recorder while you treat a single frame grab from yuor video to get the look you want, then apply the action to all the frames. Here's how: Export an image sequence in tif or targa format from your timeline, into a folder. Open that folder in Photoshop and apply the batch action to it, takes just minutes, re-import the stills back into the time line, done. Be sure you pre-set your FCP bins so that graphic imports have a single-frame duration, and I keep these image sequence folders in their own bin. A google search for "photoshop batch actions for oil painting look" will turn up a lot of easy guides to more specifics.
david bogie
on Jan 21, 2010 at 3:40:19 pm
If you expect to do this effect more than once ad can bill your clients for the look, you want a package form DigiEffects. http://www.digieffects.com/product_home
They no longer list their products conveniently by platform but most of their plugs now drop into FCP.
bogiesan
Chris Tomkins
on Jan 24, 2010 at 12:08:22 pm
Thanks for all the suggestions... Will give em a go!
Joe Monani
on May 13, 2014 at 6:48:41 am
hi, dude, why so complicated, i just brought some pieces oil painting from http://www.oilpaintinggallery.net, they provide good service and do a great job.... you can try and good luck.
JM
Stephen Smith
on May 13, 2014 at 2:28:59 pm
Got to love Spam.
Stephen Smith
Utah Video Productions
Check out my Vimeo page
