Is it a plugin for FCP, Motion Behavior or keyfreamed animation ?
COW Forums : Apple Motion
Fredy Schwerdtner
on Jan 6, 2010 at 5:59:54 pm
Hi everybody ... I am starting a production which we will insert some images ( vector drawings, photos and some other kind of images ) and we would like to make an effect that is used in a video we found in this link :
Is it a behavior as the ones used on Motion or plugins used on FCP ?
Thanks a lot in advance.
MacBook Pro 17"
2.5 GHz Intel Core 2 Duo
4GB 667 MHz DDR2 SDRAM
(2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
OS X 10.5.7
Final Cut Studio 2
Stephen Smith
Re: Is it a plugin for FCP, Motion Behavior or keyfreamed animation ?
on Jan 6, 2010 at 6:08:09 pm
Which effect are you talking about. Can you give us the time in the video that it occurs at?
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Fredy Schwerdtner
on Jan 6, 2010 at 6:54:05 pm
It practicaly occurs all over the video. You can see it beggining at 00:43 . I'm talking about the blinking / shaking and little distortion of the drawings.
MacBook Pro 17"
OS X 10.5.7
Final Cut Studio 2
Stephen Smith
on Jan 6, 2010 at 7:16:33 pm
Got it. Check out the Wriggle behavior. Go to Add Behavior, Parameter, Wriggle. Change the Apply To section to: Transform, Position. Drop the Amount to about 4 and you will get a nice jerk in the objects movement. You can do the same for the Opacity but I think you will like the Randomize option better. Go to Add Behavior, Parameter, Randomize. Change the Apply To section to:Object, Opacity. This should get you started. Mess around with the settings and other Parameter Behaviors if you like. Best of luck and hope this helps.
Stephen Smith
Fredy Schwerdtner
on Jan 6, 2010 at 7:42:42 pm
Thanks a lot Stephen. I will let you know how it worked out !
MacBook Pro 17"
OS X 10.5.7
Final Cut Studio 2
Stephen Smith
on Jan 6, 2010 at 7:46:08 pm
Sweet, happy to help. It sounds like this is going to be a fun project.
Stephen Smith
