Any way to bend an object to match a curved surface?
COW Forums : Apple Motion
Phil Williams
on Dec 25, 2009 at 8:50:53 pm
Is there any way in Motion 3 to bend an object so that it appears to be part of a curved surface?
Specific example: I recently wanted to make some text look like it had been painted onto the curved wall of a circular tunnel. I could get the perspective roughly right but the text still looked flat, it didn\\\'t look like it curved with the tunnel wall.
david bogie
Re: Any way to bend an object to match a curved surface?
on Dec 27, 2009 at 7:24:30 pm
Not in 3D space, no. Motion only understands flat layers.
bogiesan
Stephen Smith
on Jan 4, 2010 at 6:15:05 pm
bogiesan is right. With text you can try to fake it by selecting the text. Go to the text's Layout tab. Change the Layout Method from Type to Path. There you can curve the text. Next change the text's 3D rotation so it looks like it is going further away. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
