Creating a dotted path with an object
COW Forums : Apple Motion
Faraz Mozafarian
on Dec 23, 2009 at 1:40:26 am
Hello,
I am sure this is a very simple question for most of you out there. I wanted to create an animation similar to a planes path over a map where the path is a dotted/broken line. But instead of the path being small dots I wanted the dots to be made up of an image I have.
How would I go about doing this?
Thank You in advance!
Faraz Mozafarian
Re: Creating a dotted path with an object
on Dec 23, 2009 at 2:00:54 am
Never mind. I figured it out. :)
Thanks Anyway.
Mark Spencer
on Dec 23, 2009 at 2:53:54 pm
Read up on how to use the Replicator, it's the tool you want to use. Basically:
1) Draw a path with the bezier shape tool
2) Replicate your image
3) Set the Replicator Shape to Geometry
4) Drag your path to the well
5) Use a Sequence Replicator behavior to animate the replicated images along the path.
Here's a tutorial:
http://www.motionsmarts.com/tutorials/drawinglines/drawinglines1.html
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Bill McLellan
on May 8, 2015 at 6:06:04 pm
So, will this create the same effect of marching ants? I am trying in Motion to have a dashed line continuously move. I have gotten a dashed line to move with a rate behavior and adjust the offset. I really can't control the speed of the movement. Any help would be greatly appreciated.
