Can you add motion blur selectively or is it always global?
COW Forums : Apple Motion
Phil Williams
on Dec 14, 2009 at 12:41:01 am
Does Motion allow to you to switch on motion blur just for specific layers, or does it have to be global?
Mark Spencer
Re: Can you add motion blur selectively or is it always global?
on Dec 14, 2009 at 1:40:40 am
It's global.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
zak peric
on Dec 14, 2009 at 8:26:47 am
It is a global thing. You could apply motion blur to objects in your projects to preview what could be motion blur. You can also solo the layer and do a render preview with motion blur on. to solo the layer first select the layer or a group then go to object and press solo. Then do a ram preview.
Phil Williams
on Dec 14, 2009 at 8:26:12 pm
Thanks for the responses guys, although it's not what I wanted to hear :(
I'm just about to start a project where I'd like foreground graphics to be motion-blurred while background graphics stay crisp, so I guess the only way to achieve that would be to render out the foreground graphics separately with motion blur and an alpha channel, and then composite them onto the backgrounds?
zak peric
on Dec 14, 2009 at 8:34:43 pm
See, you knew the answer all along.This is a good attitude to have, find a fix to a problem, implement it and move on.
