[txt] outline issue - what is the status of the text engine. Outline gets cutoff
COW Forums : Apple Motion
Helge Tjelta
on Dec 12, 2009 at 9:39:11 am
When putting on the outline on a text, it seems to cut of the outline. Looks like the outline is inside a max square around each letter.
Type a 0 (zero) and put on a big outline for about 6. Watch the edges, no nice round circle at the top and the bottom, looks like it gets cutoff somehow.
What is the status of the text generator in Motion, is it really good ? Or can we use other generators that also publish it self to FCP for the input.
sincerely Helge
Helge
Mark Spencer
Re: [txt] outline issue - what is the status of the text engine. Outline gets cutoff
on Dec 12, 2009 at 2:16:34 pm
I'm not seeing that issue, perhaps it's the font you are using? I'm getting nice curved edges on my outline. I find Motion's text engine to be quite excellent.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Arnie Schlissel
on Dec 12, 2009 at 4:16:20 pm
select the layer that the type is in and make sure that it's set to "Fixed Resolution" and that the resolution is the same as the Motion project.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Helge Tjelta
on Dec 12, 2009 at 4:58:16 pm
well, fixed resolution does not do any difference.
Helge
Helge Tjelta
on Dec 12, 2009 at 5:01:29 pm
421_outlinemacpro.png.zip
Inspect this one... check the corners and roundness, they are cut off.
Helge
Helge Tjelta
on Dec 12, 2009 at 5:07:31 pm
422_txtoutlineproblems.zip
here is the link for all the different programs
sincerely Helge
Helge
