Track Point something
COW Forums : Apple Motion
Chih Fong Pan
on Dec 9, 2009 at 11:00:03 am
How Can I apply Shape_Track Point behavior to track Paint Stroke with Shape_Write On behavior (arrow head) ? or another way got it ?
Stephen Smith
Re: Track Point something
on Dec 9, 2009 at 3:37:38 pm
If you want to just track the arrow head I would use the Match Move Behavior in the Motion Tracking Behaviors section.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Mark Spencer
on Dec 9, 2009 at 3:42:48 pm
Did you get that to work, Stephen? I don't see how you can match move a control point of a shape to the movement of the arrowhead unless you first bake the arrow animation as a movie.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Stephen Smith
on Dec 9, 2009 at 4:16:40 pm
Good point!
Stephen Smith
cowcowcowcowcow
Mark Spencer
on Dec 9, 2009 at 3:40:18 pm
I think you are going to have to export your arrow animation as a movie, bring it back in, and then analyze the motion of the movie with a tracker on the arrow head - then track the point of your balloon shape to the arrowhead.
Mark Spencer
Chih Fong Pan
on Dec 10, 2009 at 1:47:02 pm
Thanks everybody help, I Know How to do that (Export and Analyze). But have another behavior or tricks and tips do that?
cowcowcowcowcow
Andy Neil
on Dec 12, 2009 at 7:28:06 pm
Here's what I'd do:
Create a null object. Basically a small shape like a square or circle. Add the Motion Path behavior to it. Change the path shape to geometry and add your paint stroke or line as the path shape. This will force the null to follow the same path as the write on to your arrow.
Then apply the track points behavior to your text bubble and use the null shape as the source. Make sure to turn off the null so it doesn't appear in your scene.
As you may or may not know, you can limit which points in your text bubble are affected by the track points behavior. By default, they all are, but all you have to do to limit this is (with the behavior selected) CMD+click on the points you don't want to move. They will turn blue in the canvas.
Here is a link to a sample project in case my explanation wasn't clear enough.
423_trackpointsbehavior.motn.zip
Hope this helps.
Andy
Chih Fong Pan
on Dec 13, 2009 at 2:56:40 pm
Great!!!!!
So cool, that is new concept for me! thanks a lot! show me a new world from behavior!
Apple Certified Trainer - Final Cut Pro 7 Level One
Mark Spencer
on Dec 13, 2009 at 6:52:02 pm
Outstanding solution, Andy. One thing to add - you need to make sure that the Motion Path behavior has the same location and duration as the Write-On behavior for this to work - but if you do, it works perfectly. Very nice.
Mark Spencer
