Banding
COW Forums : Apple Motion
Brian Bacardi
Banding
on Dec 3, 2009 at 7:53:09 pm
Kind of a novice with Motion. When creating a project, and adding a vignette, playing it back with the animation codec looks great. The problem is it has to be in 264. Every time I encode the project with the highest quality settings using 264, I get banding. Any ideas on how to eliminate this?
Any help is greatly appreciated!
Brian
Mark Spencer
Re: Banding
on Dec 3, 2009 at 7:57:17 pm
Adding some noise can help break up the banding - use the Noise generator, set the opacity very low, overlay blend mode.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Stephen Smith
Re: Banding
on Dec 3, 2009 at 10:25:55 pm
Check out the "Reduce Banding" filter in the "Color Correction" filters section. Best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Mark Spencer
Re: Banding
on Dec 4, 2009 at 4:15:30 am
Great solution, Stephen, I forgot all about that filter!
Mark Spencer
zak peric
Re: Banding
on Dec 4, 2009 at 9:32:13 am
HI everybody,
I just wanted to say that when exporting movies with gradients in H264 codec binding is something that occurs all the time. This is all to do with how quicktime H264 examines and compresses the pixel. The solution is always to add the noise (thanks Stephen for point to the Reduce Binding Filter). If you rely want to know why this happens Grayscale Gorilla has a good video tutorial were he talks about this subject. Please note it is for After Effects users, however solution to the problems is identical to Motion Users. See this link for more info: http://greyscalegorilla.com/blog/2009/10/how-to-remove-banding-artifacts-in...
I hope this helps.
Brian Bacardi
Re: Banding
on Dec 3, 2009 at 10:34:06 pm
Thanks Mark and Stephen-
It seems like you both have the same concept. Mark, I was working with your idea for a while, and got a little improvement. Stephen, once I tried the Color Correction - Reduce Banding Filter... Yahtzee!
Thanks again for your help!
Brian
Stephen Smith
Re: Banding
on Dec 3, 2009 at 10:38:02 pm
Brian,
Happy to help. Best of luck.
Stephen Smith
