Analyze motion hangs
COW Forums : Apple Motion
Mark Madsen
on Nov 30, 2009 at 4:35:49 pm
My Analyze motion hangs in Motion 4
I am analyzing a 10 minute clip. Takes an hour with no problems but then the icon changes to holding and Motion stalls and hangs. Nothing I am doing on my end except importing the file with or without sound. Maybe it's a setting. Maybe the clip is to too jittery in some places?
Would help if it gave an error message then.
Mark Spencer
Re: Analyze motion hangs
on Nov 30, 2009 at 5:34:17 pm
10 minutes is way too long a clip to use optical flow on - it will create a massive cache file that can crash your system.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
Mark Madsen
on Nov 30, 2009 at 5:53:28 pm
OK, it's working now on a smaller area of the clip using markers.
Also I used the Analyze Motion bvehavior. How can I combine that with Stabilize so I don't have to re-analyze?
Mark Spencer
on Nov 30, 2009 at 6:09:59 pm
Not sure what you are trying to accomplish. If you want to stabilize the clip, just use the Stabilize behavior, you don't need to apply the analysis separately. Or you can use SmoothCam in FCP, it does the exact same thing.
Mark Spencer
Mark Madsen
on Nov 30, 2009 at 6:25:05 pm
OK, I will experiment. Also I wanted to say that I analyze large clips in the software called IStabilize without a hitch.
