Motions library in AE
COW Forums : Apple Motion
Amir Abed
on Nov 23, 2009 at 7:26:14 am
This may be a stupid question but I have to learn after effects for work and I was wondering if its possible to use all the great stuff (mainly the particle emitters, and the content folder) from motion. Or does after effects come with its own bag of goodies? Thanks.
Stephen Smith
Re: Motions library in AE
on Nov 23, 2009 at 5:16:36 pm
After Effects has it's own Particle Emitter. You can use all of the "Content" in Motion that are images or Movies. Everything else like the Lines need to be used in Motion because they are built with a tool in Motion. You can always export out those objects like the Arrow but that would be a lot of work. If your on Motion 2 you may find this of interest but once again. A lot of work: http://www.automaticduck.com/products/piae/
After Effects does come with its own content that is worth looking at. Hope this helps and best of luck.
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
zak peric
on Nov 24, 2009 at 7:20:20 am
no you can not. But you can always use rendered movies of particle systems inside After Effects. You can also navigate to motion library and use shapes for particle systems in AE. AE have good tools you only need images to make particle systems. I also suggest you get Trapcode Particular 2 for AE as it is the best particle system around.
