PSD pixelation when brought into FCP as a motn clip
COW Forums : Apple Motion
Jon Campbell
on Nov 19, 2009 at 2:34:54 am
I'm just getting started with motion and have run into a problem with a photoshop layer pixelating in the trip over from motion. I've made sure everything is Safe RT, high quality in my sequence and that motion files are rendered at high quality. This 45 sec screen capture video shows the problem. http://tinyurl.com/yela33o
Any ideas?
Kellie Crowe
Re: PSD pixelation when brought into FCP as a motn clip
on Dec 23, 2009 at 1:52:43 am
Jon,
I'm having the exact same problem. I'm hoping you've either figured out a solution or someone has helped you remedy your problem. If you could post the "fix," I would certainly be grateful.
K. Crowe
Mark Spencer
on Dec 23, 2009 at 3:11:55 am
You need to understand how the Canvas works in FCP - it is not showing you final quality. This may help:
http://www.kenstone.net/fcp_homepage/motion_text_in_fcp_spencer.html
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
http://www.applemotion.net
