Apple Motion and vector images
COW Forums : Apple Motion
Alex Ordiner
on Oct 28, 2009 at 11:21:57 am
first of all - sorry for my "google" english
second: I need to work with vector images, but I noticed that Apple Motion accepts only pdf images. Is it right?
I try to convert AI or SVG files with Automator, but I failed.
Thanks. Alex
Stephen Smith
Re: Apple Motion and vector images
on Oct 28, 2009 at 2:13:52 pm
You can import AI files into Motion and if set right you can maintain its vector quality.
Your Illustrator file needs to be RGB and not CMYK. Be sure to save the AI file with PDF compatibility. After you bring it into Motion, just select it, press Shift+F (takes to you the Media tab), then uncheck the Fixed Resolution checkbox. This will allow the vector image to be rasterized at whatever size it is on-screen. Hope this helps.
Stephen Smith
Utah Video Productions
Check out the Graphics Demo Reel I did.
Check out my Motion Tutorials
Alex Ordiner
on Oct 28, 2009 at 2:27:33 pm
thank you very much Stephen!
I knew the "fixed resolution" checkbox, but not the AI - CMYK incompatibility..
So, I just have to find an automatic way to convert them.
thanks to you and to all of you!
Alex
Stephen Smith
on Oct 28, 2009 at 3:27:02 pm
Happy to help. Do you have access to Adobe Illustrator?
Stephen Smith
Alex Ordiner
on Oct 28, 2009 at 3:37:59 pm
yes I do. In bundle with AE
But I not found any kind of batch operation
Stephen Smith
on Oct 28, 2009 at 4:09:00 pm
So you have a bunch of AI files you want to convert over to RGB?
Stephen Smith
Alex Ordiner
on Oct 28, 2009 at 4:32:22 pm
yes, a no pdf-compatible vector icon format.
I also have a lot of .svg
but tomorrow i wil try to record an action with automator (mouse action record)...
I hope it works
Thanks again
Stephen Smith
on Oct 28, 2009 at 7:41:25 pm
Sounds like a great idea. Let us know if it works.
Stephen Smith
mark pigott
on Nov 4, 2009 at 9:16:37 pm
I came out of my Windows illustrator as a PDF compatible .ai file.
Apple Motion will not read the CS4 noway-no how.
Is it another..."gee, you better buy the Mac version of the Adobe Suite" ????
Stephen Smith
on Nov 4, 2009 at 9:34:20 pm
Can you upload an AI file so I can take a look at it? Use the File Upload button which is the last icon that is a floppy disk symbol.
Stephen Smith
mark pigott
on Nov 5, 2009 at 9:53:30 pm
Let me ftp it- the uploads don't work here.
Just email me and I will set up an ftp here at work
Stephen Smith
on Nov 5, 2009 at 9:57:55 pm
Here it is:
Stephen Smith
mark pigott
on Nov 5, 2009 at 10:00:20 pm
here is the ftp
stillwaterfilms.com/testformotion.ai
Stephen Smith
on Nov 6, 2009 at 6:05:50 pm
Sorry Mark, it opened up with no problems on my machine. I looked at the manual and it doesn't say that the file needs to be created on Mac version of the program. See if this AI file works.
366_test.ai.zip
Stephen Smith
mark pigott
on Nov 6, 2009 at 8:33:52 pm
"Sorry Mark, it opened up with no problems on my machine. I looked at the manual and it doesn't say that the file needs to be created on Mac version of the program. See if this AI file works. "
I took the 366_test.ai from the desktop and saved in in a test directory, but whether I imported
from the file\import menu or from the media import + button or the media\import function the
366_test.ai is greyed out.
I am running Motion 3.02
Stephen Smith
on Nov 9, 2009 at 3:54:15 pm
I'm not sure why it is not working. My best guess is to trash your preferences. Take a look at this article.
http://support.apple.com/kb/HT1885
Stephen Smith
mark pigott
on Nov 19, 2009 at 4:11:13 pm
I just trashed the preferences and it still doesn't work.
Luckilly I still have 3ds Max and Adobe Suite CS4
as backups...
