Importing back to FCP
COW Forums : Apple Motion
Francis Robertson
on Oct 25, 2009 at 11:25:20 am
Hi, I was just wandering if there is a way to export back to FCP with an alpha channel?
I want to create a cloud transition effect using the cloud generator. It would be nice to be able to just place it on the FCP timeline whenever I want with the alpha channel info there.
All I seem to be able to do is export a flattened quicktime which I then re-import back to FCP.
I hope I am making sense, please ask if you need further clarification.
Hope you guys can help.
James Carroccio
Re: Importing back to FCP
on Oct 26, 2009 at 1:18:17 am
i to have the same problem. what do you mean by alpha channel tho?
James
Camera Operator
Francis Robertson
on Oct 26, 2009 at 7:45:22 am
I mean a black and White outline of the object that allows me to make blank areas transparent to reveal the video track below.
Francis Robertson
on Oct 26, 2009 at 7:45:28 am
Stephen Smith
on Oct 26, 2009 at 2:14:26 pm
If you import the motion file directly into your Final Cut Pro timeline you maintain all of the Alpha Information. If you want to export a video I find this to be the easiest:
File, Export. Click on Options... Change compressor to Animation. Click on the Advanced button. Make sure it is set to Millions of Colors +. The plus is the alpha channel.
Stephen Smith
Utah Video Productions
Check out the Graphics Demo Reel I did.
Check out my Motion Tutorials
