Motion exporting background on .png file?
COW Forums : Apple Motion
Kurt Uebersax
on Oct 22, 2009 at 4:58:34 pm
I'm new to motion, setting up a basic 2D left-right move across the screen (move behavior). All looks good, but when I export to a quicktime file (to import into FCP), it comes in with a black background. File is a .png file, I have the transparent checkerboard on the canvas.
The eventual look is to have this image superimposed over other video images.
Did I miss something in preferences or the setup?
Best,
Kurt Uebersax
http://www.kjuproductions.com
Noah Kadner
Re: Motion exporting background on .png file?
on Oct 23, 2009 at 3:26:04 am
Doe PNG include an alpha? Try PSD.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, and Panasonic DVX100.
Call Box Training
DSLR Cinematography Blog
Jason Diebler
on Oct 23, 2009 at 12:02:00 pm
Noah is right, you need an alpha channel. You may need to export animation codec. It sounds like your Quicktime export is flattening your Motion project (excluding any alpha channel you may have had). If you initially roundtrip from Final Cut, you'll bypass the need to do any exporting out of Motion, you'll retain your alpha channel. So either roundtrip (to integrate your .motn file in your FCP project) or export animation... what version of Motion are you using by the way?
"The deepest blues are black" - Foo Fighters
(this doesn't help me when I'm chroma keying!)
Stephen Smith
on Oct 23, 2009 at 4:45:41 pm
A png will do a Alpha Channel. Make sure it is set to Millions Color + which is under the Advanced tab in the Export Option section. That works for stills. If you doing a video set it to Animation at Millions Colors +. Best of luck.
Stephen Smith
Utah Video Productions
Check out the Graphics Demo Reel I did.
Check out my Motion Tutorials
zak peric
on Oct 23, 2009 at 5:05:37 pm
Just to add to this subject. I agree with everything that is said on this topic. Also new 4444 codec from Apple Motion can export a alpha channel using the millions + (for animation). Please also note targa is good to export with alpha from 3d programs, also a common for images would be tiff or tif as it is another file type that can export Alpha.
if you are working with Photoshop then use Psd or Png.
I hope this helps.
Kurt Uebersax
on Oct 30, 2009 at 4:00:09 pm
Thanks all,
It was the codec/alpha channel. I used 4444 and it worked fine.
Best,
Kurt Uebersax
