Motion exporting compression problem
COW Forums : Apple Motion
Trish Hagen
on Oct 16, 2009 at 8:01:07 pm
I just finished a motion text animation project that I need to use FCP. I am using Motion 3 and when I exported it using animation compression it looks all pixilated and not the look I want. Any one know what compression would be best? thanks
Stephen Smith
Re: Motion exporting compression problem
on Oct 16, 2009 at 9:12:40 pm
I export out movies using the Animation codac all the time. This TV Show Open used the Animation setting. I've found that if text looks bad, make sure you export out your video set to Best instead of Normal. Go to File, Export. Options. Click on the Output tab and un-check the "use current project and canvas settings" check box. Set Render Quality to Best. Hope this helps.
Stephen Smith
Utah Video Productions
Check out the Graphics Demo Reel I did.
Check out my Motion Tutorials
zak peric
on Oct 17, 2009 at 7:43:34 am
I would agree with Stephen.
