Curl an image in 3D space from the XY plane - Motion 4
COW Forums : Apple Motion
Chris Finley
on Oct 3, 2009 at 11:37:48 am
I'm trying to find a way to take an image/video, and curl it in 3d space - essentially wrapping the image to the inside of a hollow cylinder. I've tried playing around with all the standard filters and they all seem to just alter the image when viewed from straight on but are always flat viewed from the side....
I've attached a video of my project so far, which is 24 hexagonal rings of multiple dropzones that the camera flies through - I'm tring to bulge out the center of each dropzone so the ring shape will be a smooth circle instead of a hexagon
example: http://finleycs.com/other/dropzone-wormhole.html
Chris Finley
Re: Curl an image in 3D space from the XY plane - Motion 4
on Oct 3, 2009 at 10:46:43 pm
also I should point out that this is for a Motion class project, so a solution involving After Effects or another program wont help me here.
Noah Kadner
on Oct 3, 2009 at 11:38:16 pm
Motion is not true 3D- objects can move in 3D space but they have no z depth.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, and Panasonic DVX100.
http://www.callboxlive.com
DSLR Cinematography Blog
Chris Finley
on Oct 3, 2009 at 11:50:18 pm
bummer, I was afraid that would be the case... is there any Motion 4 plugin that might help bend the objects this way, or atleast let me remap XY space from Cartesian to Polar coordinates so that all points of the dropzones would remain r distance from the center?
Thanks for the Help
Noah Kadner
on Oct 4, 2009 at 6:11:21 am
Nope if you want true 3D get a 3D program like Maya, C4D, LightWave, etc...
Noah
zak peric
on Oct 4, 2009 at 8:10:20 am
Well, it is possible to bend the shape in Apple Motion. Although you will need a third party plugin Boris Continuum 6. This plugin have some amazing tools and filters. A particular set of filters from Boris 6 you need are called BCC 3d Objects, they have built in deformers and dynamics, it is scary to see true 3d in Motion. See my review here: http://embryo.me.uk/wp/2009/09/06/review-of-boris-continiuum-6/
