Playback Jumpy
COW Forums : Apple Motion
Michael Ford
Playback Jumpy
on Sep 17, 2009 at 11:14:32 pm
Hi, at first when i started using Motion everything would play fine. now i am finding it jumpy when i play anything back but the audio playback is fine. whether it be a simple text in and out or a video for adding text overlays. everything is fine if i export it though. i dont want to export everything every time i want to play it back. is there a setting i need to change?
zak peric
Re: Playback Jumpy
on Sep 17, 2009 at 11:38:47 pm
delete the preferences of motion and restart it. see if this helps.
thy are in home folder/library/preferences/ look for something like com.apple.motion.plist
Also reset you Parameter Ram on your mac.
Michael Ford
Re: Playback Jumpy
on Sep 18, 2009 at 12:17:33 am
unfortunatly nothing has changed. Trashed the Pref's and reset PRAM. but nothing has improved.
zak peric
Re: Playback Jumpy
on Sep 18, 2009 at 12:20:50 am
What computer do you have. And how much ram and what graphic card please.
Michael Ford
Re: Playback Jumpy
on Sep 18, 2009 at 12:30:51 am
MacPro - QuadCore, 3GB RAM, NVIDIA GeForce GT 120
zak peric
Re: Playback Jumpy
on Sep 18, 2009 at 12:37:33 am
looks like it is going ot be difficult to pin point the problem. If I was you I would first fix permissions (at least few times) restart the computer. And if this does not help I would reinstall motion from a original disk. This should solve you problem I hope.
Michael Ford
Re: Playback Jumpy
on Sep 18, 2009 at 12:41:48 am
ok. thanks for the help, unfortunatly its getting really late and i have work in 5 hours and need sleep. i will try again tomorrow (later today) and see what happens, thank you.
Stephen Smith
Re: Playback Jumpy
on Sep 18, 2009 at 6:53:32 pm
Michael, here is a link to an article that I think will help. Zak already covered some of it.
http://support.apple.com/kb/HT1885
Stephen Smith
Lone Peak Productions
Check out my Motion Tutorials
