Send to Motion
COW Forums : Apple Motion
Ricardo Santos
Send to Motion
on Sep 13, 2009 at 9:39:48 am
I make one freeze frame of my clip (on final cut pro) and then i insert on the place that i want. After i choose "send to motion project" (because i need to draw some arrows and squares on my freeze frame). When i do this the freeze frame that appears on motion its not the same that i choose on final cut project (appears on another place of the clip)!
How can i solve this?
My solution until now (to much time) was to export the freeze frame like picture, insert on my clip and after send to motion. In this case i can do what i want, but it will be very easy if i can edit directly from the freeze frame.
Anyone can help me with this?
Noah Kadner
Re: Send to Motion
on Sep 13, 2009 at 12:47:53 pm
Don't think that works- Make Freeze Frames in FCP is unpredictable so stick with export still.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
http://www.callboxlive.com
zak peric
Re: Send to Motion
on Sep 13, 2009 at 4:46:35 pm
I agree,
Also the way you are doing ti will give you more flexibility.
