field order not correct in FCP
COW Forums : Apple Motion
toby stanier
on Sep 11, 2009 at 10:41:10 am
I'm working on a 30 second PAL HDV project.
I've set the the presets in Motion to have the Field Order to be Lower (Even). And in FCP my Sequence Presets is set to Lower field. But when I import my Motion file into FCP the item properties are telling me that the field Dominance is Upper(odd).
Does anyone know hat am I doing wrong here?
Toby
Noah Kadner
Re: field order not correct in FCP
on Sep 11, 2009 at 3:18:28 pm
I was under the impression PAL HDV was always upper...
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
http://www.callboxlive.com
zak peric
on Sep 11, 2009 at 7:44:49 pm
I am not an expert on FCP, but I would apply deinterlace filter in FCP, this should fix the problem.
Noah Kadner
on Sep 12, 2009 at 12:03:29 am
[zak peric] "I am not an expert on FCP, but I would apply deinterlace filter in FCP, this should fix the problem."
Do that only if you want to halve the resolution of your footage. Otherwise stick with upper field dominance, this is interlaced footage.
Noah
Arnie Schlissel
on Sep 11, 2009 at 9:10:52 pm
1080i is always upper field first.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
zak peric
on Sep 12, 2009 at 5:35:30 am
I just did a research on internet seems that upper is the way forward.
