Scrolling/Movement Not Constant
COW Forums : Apple Motion
John Locke
on Sep 8, 2009 at 7:52:56 pm
Whenever I try to scroll end credit text in Motion, regardless of the method (whether making the credits out of text or as an image or PDF)...and also when applying the Burns Effect to a large image, I'm getting inconsistent scrolling speed. It always starts slow, speeds up, then slows down again at the end. I'm not sure why this happening since there are only two keyframes... one with the item in the start position, and one at the end with item in the end position.
I've messed around with settings, and found the one labeled "Constant Speed"... but that doesn't seem to help.
Any ideas on what I'm doing wrong?
[Motion version 3.0.2]
Stephen Smith
Re: Scrolling/Movement Not Constant
on Sep 8, 2009 at 8:02:25 pm
Hit the command and 8 keys to open up the keyframe editor. Select your key frames and right click on one. Go to interpolation in the pop-up menu. Choose Linear instead of Bezier. That will make the movement a constant speed instead of easing it in and out.
Stephen Smith
Lone Peak Productions
Check out the TV Show Open I did.
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
John Locke
on Sep 8, 2009 at 8:17:51 pm
Now THAT I would never have found without your help. Thanks very much!
Stephen Smith
on Sep 8, 2009 at 9:18:52 pm
Happy to help.
Stephen Smith
