 | Weird scaling issue when rotating shapes....??
on Sep 1, 2009 at 3:42:10 am |
I have a bunch of shapes in a composition. They are in a group, which i scale down to fit into my scene. But when i go to rotate the shapes, they start to distort and scale sideways in a big way. Whats going on?
 | Re: Weird scaling issue when rotating shapes....?? on Sep 2, 2009 at 7:37:09 pm |
I cannot see nor even imagine what you're seeing.
Are you sure they're scaling? does the scale parameter change? Are they 3D layers? Is the group 3D? Around what axis are you rotating?
bogiesan
 | Re: Weird scaling issue when rotating shapes....?? on Sep 3, 2009 at 12:25:32 am |
Yeah for sure they are scaling. WHen im in front view it just looks crazy, like they are suddenly in a funhouse mirror, they stretch towards both horizons. When i check from a perspective view, they do the same. Just stretch massively when i rotate. Im not working in 3D, but changed to 3D with a camera to check if it was happening from all angles, and it was.
