Trouble importing TIFF file
COW Forums : Apple Motion
Atticus Brady
on Aug 9, 2009 at 3:56:08 am
Greetings,
I took a frame from a piece of video in my Avid at work, exported it as a TIFF file at 720x486 so I could work with it in Motion at home, but Motion won't import the file. Neither will FCP. What am I doing wrong?
Peter Wiggins
Re: Trouble importing TIFF file
on Aug 9, 2009 at 5:07:57 pm
What file extension has it got?
Peter
Atticus Brady
on Aug 9, 2009 at 5:13:47 pm
The file extension is .tif. When I select one in Motion in the file browser it does not appear in the thumbnail window and hence will not import.
Peter Wiggins
on Aug 9, 2009 at 6:45:37 pm
Can you drag it from the desktop straight onto the canvas?
Peter
Atticus Brady
on Aug 10, 2009 at 3:37:40 am
Hi Peter,
Dragging from the desktop is a no-can-do. Dragging the file onto the canvas and releasing simply snaps it back to its position on the desktop. Perhaps it's a TIF thing. I'm going to try exporting the frame grabs as JPEGs, unless you have any other thoughts...
Atticus
Petter Brox
on Aug 10, 2009 at 9:26:15 am
Maybe you saved the file as 16bit CMYK or 32bit RGB?
Petter Brox
Atticus Brady
on Aug 10, 2009 at 11:22:23 pm
Figured it out. Nothing wrong with the Tiff format. What I had done was create a one-frame subclip from a longer master clip and exported it as a TIFF file. I think the fact that it was only one frame in duration didn't allow Motion to see the file. I went to the original master clip, marked in/out on the frame I wanted and exported that. That, for whatever technical reason, created a tiff of longer duration which Motion then recognized and imported just fine. Thanks for getting back to me guys!
