How to rotate Anchor Point??
COW Forums : Apple Motion
Tony Yarven
on Aug 6, 2009 at 6:04:05 am
I have something in an image which is at a 45% angle to everything else. I have duplicated it, masked it, and now want to animate it getting taller, but because it was originally part of the whole image, it scales straight up, distorting it.
How can I rotate the bounding box/anchor point, so that when i scale it's Y value, it will scale upwards at a 45% angle and not distort??
Thanks.
Stephen Smith
Re: How to rotate Anchor Point??
on Aug 6, 2009 at 3:10:27 pm
The scale is based on the position of the anchor point. go up to the view tools and hold down the mouse on the "Select" tool. In the drop down menu select the second tool down which looks like a circle. It will allow you to move the anchor point to the opposite corner of where you want the object to scale up.
Stephen Smith
Lone Peak Productions
Check out the TV Show Open I did.
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
