field render vs. non
COW Forums : Apple Motion
J. Tad Newberry
on Aug 3, 2009 at 6:55:32 pm
one of the main default export settings out of Motion i use is "Lossless + Alpha Movie", and it is defaulted to non field render, so i made a new setting that is field rendered. i've rendered out the same project both ways and see no noticeable difference. am i crazy or shouldn't a field rendered movie look a lot smoother (at least where images are moving) than a non field-rendered??
Thanks again!
J. Tad Newberry
Big Ya Productions
Mac Pro 2.66 GHz Quad-Core
3 GB RAM
http://www.bigya.tv
Noah Kadner
Re: field render vs. non
on Aug 3, 2009 at 7:51:26 pm
Field render= interlaced. You would notice the difference much more on a TV. Personally I see no reason to ever use interlace render unless you're integrating interlaced footage for an interlaced finish. Even then, interlaced animation can look iffy.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
http://www.callboxlive.com
