Auto Orienting to Camera
COW Forums : Apple Motion
Nathan Trenkamp
on Jul 15, 2009 at 6:16:02 pm
I"m wondering if there is a way for the object in 3d space to auto orient to the camera like it can in After Effects. Thanks in advance.
Stephen Smith
Re: Auto Orienting to Camera
on Jul 15, 2009 at 6:25:45 pm
Put it in its own group and make the group 2D.
Stephen Smith
Lone Peak Productions
Check out the TV Show Open I did.
Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Jim Johnson
on Jul 16, 2009 at 9:54:48 pm
Howdy,
If you're referring to an object that has a position in 3D space but always faces the camera, you can achieve that by applying the Point At behavior to the object. In the behavior's settings, set the camera as the target and set the Transition value to 0% (which means that it won't turn to the camera over time, but immediately/always be facing the camera).
Nathan Trenkamp
on Jul 16, 2009 at 10:22:20 pm
Excellent! That's what i needed to know. Thanks Jim!
